multiplotting on same chart and selecting individual plots
I have used bundle pallete in clusters to display two plots on same waveform chart. The vi when run displays both plots which is very good. I wonder if its possible to show either plot 1 only or plot 2 only or both by user's choice for instance, clicking some icons.
Many thanks in advance for help
Cheers!
(2,359 Views)
Did you perform a search for this? It's been asked numerous times.
You would first set the ActivePlot property and then the Visible property.
(2,357 Views)
