How to debug the "Write KEY.vi"
I have a very standard setup and there are not any errors being thrown, but the "write key" doesn't make any changes to the file.  I've been hammering away at this for about 5 hours, its so simple it's driving me crazy.
See attached file.
I am already reading correctly from the file and key at the beginning of the VI so I know the reference and path are correct.  The FOUND? terminal is probing as true so it is able to open the file and find the key.  It just won't change the key for some reason.
Section from .ini file
[FIRMWARE LOAD PANEL]
Firmware Path = "C:\Neuronetrix_Disk\Files\Test System\Software Development\SC-1673 COGNISION TESTSET\Trunk\Bin\Firmware.hex"
-Regards
eximo
_______________________________________________
UofL Bioengineering M.S.
Neuronetrix
"I had rather be right than be president" -Henry Clay
(2,555 Views)
Accepted by eximo
Please show your entire VI.
Did you close the Config File?  That is when the file gets written out.
(2,554 Views)
Yes, the close file has a binary terminal for writing any changes.  Thanks!!
-Regards
eximo
Neuronetrix
(2,537 Views)
