How to deflect 3D surface on 3D picture control
   I mentioned in earlier posts that I'm one of the Geeks of LABVIEW (I mainly work using .NET languages). However, having a motivated community made me dare to do some automated measurements with LABVIEW.
  I capture analog voltage corresponds to strain on a test specimen (I utilize NI DAQ 6008 and signal conditioning circuit I made, so this is the easy way as many of you already know). I want to give it some stunning look by having 3D surface that is bent (deflected) according to the corresponding analog voltage.
  If someone could create a simple VI with perhaps having a slider and the 3D surface on 3D picture control for testing deflection, This would be a dream that comes true.
  Thanks to all of you in advance.
Waleed El-Badry MSc.,MCPD, ISTQB Certified Tester
Assistant Lecturer
Mechatronics Department
Faculty of Engineering
Misr University for Science & Technology
View Waleed El-Badry's profile on LinkedIn
(3,572 Views)
Hi there
Open the Example Finder (Help->Find Examples) and search for "3D". Start with "3D Surface Example - Fluctuating Sine Wave.vi". This will give you a good start.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(3,569 Views)
Thanks Chris for your valuable help. It did help alot. I only hope to implement 3d deflection of "3D Picture Control". Maybe by using mesh and change the dimesion programmatically.
Thanks again and all help is appreciated in this regard.
Assistant Lecturer
(3,519 Views)
Is it that difficult to achieve such a task? does anyone recommed aborting the idea and replace it with charts?
Assistant Lecturer
(3,491 Views)
The 3d picture control is;
1) quite complicated for the caual developer
2) Still new enough that I have not tried it in an app (due to reported bugs)
So I can't step up and say "take a look at this thread".
I'd first try to do it using a the CW 3d graph (since I know that critter) but even for that approach I'd need a good expresion to relate the strain to deformation.
Ben
(3,488 Views)
Hi, I've seen this therad:
http://zone.ni.com/devzone/cda/tut/p/id/7130
The article has the 3D deflection that I seek. If anyone managed to generate such a thing, I'll be so grateful.
Have a nice day.
Assistant Lecturer
(3,015 Views)
