UDP with two ethernet of Compactrio
Here's my problem, I have to do an UDP data transfer,
I want to write on another computer in a .txt using the two ethernet of a compactRIO (9022)
I make a schema to be more clearly :
http://www.hostingpics.net/viewer.php?id=470011reseaujpg.jpg
I have to work on a real time project so here it is my program :
http://www.hostingpics.net/viewer.php?id=568811myprogjpg.png
So the data is send to the first ethernet then write on the second ethernet ( first loop ).
Then the data is read on the second ethernet and send in C://abc.txt of the second computer (third loop) ,(the second loop is useless..)
I have few problems :
1st : When i try the programme i have an error 54 who said something like that "the network adress is ill formed and have to be type of XXX.XXX.XXX.XXX"
2nd : I don't give the ip of the second computer, i think he will never find it, what should i do?
Thanks for answering and sorry my english is not awesome..
(2,807 Views)
In the first loop it's not "read ethernet 2" but write ethernet 2
Thanks for help 🙂
(2,747 Views)
Accepted by topic author error54
Please help 😕
(2,716 Views)
