how to convert XML file into HTML file
I am using XML file to hold the data in my project.i want to display the data in the readable format to the end user. the XML file is created by using the XML engine provided by NI.
please give me some solution regarding this.
thanks
(3,063 Views)
It sounds like you need to use XSLT (although this has nothing to do with LabVIEW Smiley Happy)
LabVIEW 2012
(3,041 Views)
