How to delete cursor or plot from 3d surface plots
Hi all,
I am working with the 3D surface plot, the one thats not an XControl (active x?). In my application there is potentially lots of data, so I would like to programmatically add and remove plots to make it quicker and easier to use.
From the dialog box, see attachment, I have the option to delete a plot using the button marked. However, I cant find out how to delete the plots programmatically. Is that possible? Please advice.
In addition, removing cursors is not possible either. Yes, I can make them dissappear from the plot, but they are still in the cursor list when selecting 3D graph properties.
Anyone know what to do? Using LV2012
I appreciate your help!
Cheers,
Øyvind
Best Regards,
Øyvind
CLAD
32 bit LV2015
64 bit Windows10
(2,832 Views)
I don't think you can do it through a property node, but you could just delete the data from the array and change the active plot.
(2,805 Views)
Hi Blueprint,
If you are using the 3D Surface function in LabVIEW, open it up and add an invoke method for CWGraph3D-->Plots-->Remove, and you will be able to remove a certain plot.
Robert P-F
(2,713 Views)
