How to design LabVIEW programming for temperature monitoring using 4 thermocouples
Hi all.
Sorry if this seems a simple question but I really sorry for the troubles. I'm a new user with LabVIEW and currently using LabVIEW 8.6 for a final year project of mine. I’m trying to monitor the temperature reading in 4 different depth of pavement for every 1 hour interval continuously for 1 month duration. Basically I’ll be using 4 separate thermocouples type J and NI 9219 device. My problems are:
  1. I’m not sure how to design the LabVIEW programming for my application.
  2. How to get the temperature reading data in Excel spread sheet.
  3. How to set the min, max and average daily temperature for each thermocouple.
 Thank You.
Amanus
Thermocouples Layout:
thermocouples layout
(3,986 Views)
Accepted by AMANUS
Introduction to LabVIEW
Follow that link to some getting started tutorials. There should be all you need in there to get you going with both the software and hardware
_____________________________
- Cheers, Ed
(3,979 Views)
Thanks for the info Ed...It do helps a lot...
Amanus
(3,949 Views)
Ca i have the link or coding for the same project previously?
(2,982 Views)
