How to detect a serial printer programmatically?
I have a serial printer connected to COM Port.
Is it possible to check if it is connected, programmatically?
I tried 'VISA find resources' function, but it always lists the COM port whether the printer is connected or not.
Message 1 of 13
(7,371 Views)
Hi AJ,
can you send a command to your printer and check for the devices answer? That would be a presence test...
Message 2 of 13
(7,356 Views)
Functions -> Report Generation -> Advanced Report Generation -> Query Available Printers
Message 3 of 13
(7,345 Views)
I'm not sure the report generation function will work in all cases. It reads the printers that are configured and the default printer. I just ran it and it returned a list including a network printer to a disconnected network.
Message 4 of 13
(7,335 Views)
What kind of printer is it?
Mike,,,
Certified LabVIEW Architect
LabVIEW Champion
Message 5 of 13
(7,324 Views)
The printer is 'Star DP8340' serial printer. It is connected to the COM1 port through DB9 connector.
I tried to communicate to the device using VISA. But it returned following error.
BUt I am able to print from MS office as well as Labview report generation.
The VISA configuration details such as port name and baud rate are correct, I collected it from the windows printer port configuration. But for some reason, the Labview VISA is unable to communicate.
Message 6 of 13
(7,291 Views)
Ok, I think that the problem is that the OS sees a printer on that com port.
You get the error because you are trying to talk to a serial device on COM1 but the OS is saying you can't do that because there's a printer there. In essence, the com port is tied up or busy because the OS is using to communicate with a printer.
Mike...
LabVIEW Champion
Message 7 of 13
(7,286 Views)
Ok, does that mean it is not possible to detect the printer programmatically?
Message 8 of 13
(7,277 Views)
Most likely not easily!
LabVIEW can not access the printer since its port is likely already reserved/opened by the printer driver. VISA actually has a specific error code for ports that are normally opened by another process but the error message is a little unspecific. But most likely the printer driver has reserved the port in some non-standard way and VISA then gets some unexpected error because of that.
And the Windows API doesn't have a simple way to query the state of a printer other than if it is installed or not. An involved way may work, using EnumPrinters() requesting for PRINTER_INFO_2 data and checking the Status element in every returned printer record for the PRINTER_STATUS_OFFLINE flag, but that API doesn't count as easy to interface with the Call Library Node.
Rolf Kalbermatter  My Blog
Message 9 of 13
(7,261 Views)
I looked at the manual for your printer and on page 17 (actually page 21 of the document) is the following information on Control Codes:
CODE ENQ (05)H
FUNCTION Enquiry
OUTLINE
When this code is received, the printer outputs status data.
If it is input after text data input in the STX-ETX mode, the
printer outputs status data and the check byte.
I don't have access to this printer (or any other similar models) to try this out but could this be of any use to you?
Message 10 of 13
(7,227 Views)
