How to determine the version of LabVIEW used for a vi.
I have recently started replying to messages in the forum in order to help people out and have downloaded a few vi's to get a look. If I post a reply with attached code, it would be useful to know what version of LabVIEW the original vi was programmed with since nobody with version 6.1 or earlier can benefit from what little wisdom I have (I use 7.1). Is there a way to tell what version of LabVIEW was used to create a vi?
Cheers,
Tim
(3,523 Views)
Just open the VI, then go to "VI properties". Now press the button "Current changes" on the "general" tab.
It will tell you if the VI has just been converted from an earlier version. Highlight that line and look at the details box below. It will give you e.g. the original version and other information.
Message Edited by altenbach on 06-21-2005 09:40 PM
(3,515 Views)
You might also want to checkout LabVIEW Version Chooser at http://http://www.dataact.com/LVC.htm from Brian Gangloff.
Rolf Kalbermatter
Message Edited by rolfk on 06-22-2005 02:19 AM
Rolf Kalbermatter  My Blog
(3,513 Views)
Sorry I did not see this post sooner. Here are the links to LabVIEW Version Chooser:
Online information
 download page
Right click in Windows Explorer
Brian Gangloff
DataAct Incorporated
(3,449 Views)
Another approach that I often use is to close the VI. The dialog that pops up asking to save includes an Explain Changes button that accesses the same Properties information. After I see which version it was created with, I close the dialog and Cancel the Close VI.
LV often provides multiple ways to do the same thing.
Lynn
(3,419 Views)
