How can I add data to a file without over writing?
My  program writes data into a file. However, I would like to be able to write this data in a file where data is already strored. Could anybody tell me how to do this ( write data into a file after the last line of the same file without over-writing) ?
Any help would be great,
David
(3,126 Views)
When writing to file, you can use the append? boolean set to true.  This will append data to the end on the selected file.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,119 Views)
See attached picture:
Paul Falkenstein
(3,117 Views)
Oops the append Boolean should be true in the previous post.
Paul Falkenstein
(3,116 Views)
Thanks for ur answer falk, It now works fine.
I was using the icons Open + Write + Close.. before using ur solution. Actually I was opening only once the file and then saving my data to that file and then closing it at the end of the program only. Whereas with ur solution, it seems that the icon adds the data fine to the file by then closes it just after. I am saving the data every second at the moment.... is opening and closing the file each time I write the data a problem in my program?
Thanks a lot for ur help,
David
(3,096 Views)
Glad to help.  Good luck with the coding
Paul
Paul Falkenstein
(3,077 Views)
Opening and closing each time is not a problem, but it will slow your program down.  Leave the file open and just write each time.  Do the close before you exit.
(3,069 Views)
