Switch digital outs at a certain time on and off
I want to switch 2 Digital-Outs at a certain time on and off and at the same time I have to read 4 Analog-INs with an very high scan rate (1000 - 200000 scan per sec). I tried the example "Count time-easy (DAQ-STC).vi" and modified it a little bit for my work.
The example alone worked very well but not in my real VI.
The problem is that in my VI the time count not work and so the digital outs won't be switched.
You can see it a part of my VI in the attachment.
thanks for your helpSmiley Very Happy
I use WinXP, LabView 6.1 with DAQcard-AI-16E-4
Message 1 of 8
(3,311 Views)
what about to place the 2nd threat in a while loop, too
Message 2 of 8
(3,281 Views)
I think you mean the threat under the while-loop.
I tried to place the 2nd threat in the same loop (time count) but it did not work.
Message 3 of 8
(3,275 Views)
i mean 2 parallel while loops
Message 4 of 8
(3,270 Views)
OK. I will try this at Monday. thanksSmiley Wink
Message 5 of 8
(3,265 Views)
I tried to place the 2nd threat in a parallel while-loop but this also didn't work.
The VI stops at the right time but the time count is not refreshed!!!
Message 6 of 8
(3,255 Views)
can you publish your current VI?
Message 7 of 8
(3,251 Views)
here it is, my VI with the 2 parallel while-loops.
Message 8 of 8
(3,242 Views)
