How to disable default led event in labview
I have 1 Led in Front Panel, when I click on that, it will change the state. This should not happen for me. How to disable this one. Here the property of Led should be Control not Indicator.
Thanks & Regards,
Harish G.
Message 1 of 14
(3,863 Views)
Can you post your VI in 2011 format. Its easy to give solution from there
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 2 of 14
(3,857 Views)
In edit mode, you can change controls as well as indicators.
In run mode, only controls can be changed from the front panel, indicators cannot be operated.
(You can change a control into an indicator and vice versa in edit mode by right-clicking on the terminal. Overuse of local variables sometimes blurs the distinction between controls and indicators.
Your post is very confusing and it is not clear what you actually expect. Can you attach a small example VI that shows the problem?
Message 3 of 14
(3,855 Views)
check
Please see this. The Default Led Event is when u click on it. I t will change the state. I don't want that.
Message 4 of 14
(3,844 Views)
@HarishG wrote:
check
You need to show us the code, not a picture of the front panel. Please attach the VI and explain how you operate it.
Message 5 of 14
(3,836 Views)
Then why you are using LED ?
--Ranjeet
Message 6 of 14
(3,830 Views)
As sir said, Please post your VI
--Ranjeet
Message 7 of 14
(3,829 Views)
Hi altenbach,
    See i attached the VI file.
               1. u hv to run TempVI, then click on boolen LED
               2. Another window QuitVI will come, then press Quit to close.
               3. Now the LED is changed the state of that. (if boolen  LED is ON then it became OFF & vise versa when u click. I dont want this one The boolean LED should not change its state when u click).
Thanks & Regards,
Harish G.
Message 8 of 14
(3,824 Views)
Accepted by HarishG
Your LED is a control. Make it an indicator instead (right-click the terminal...change to indicator).
Of course if it is an indicator you can no longer use a value change event. You could use a mouse down event instead.
Why is it a LED? In the simplest case you could just color the ON and OFF state the same dark green.... 🙂
Message 9 of 14
(3,817 Views)
I want Led only, it is acting as indicator, but it is control when we click on that, we go to another window, there we will see status of some things & we will come back.
Don't think too much, I want basic thing only,  when we click  ON LED should not change the state. How to do this?(LED should be Control).
Thanks & Regards,
Harish. G
Message 10 of 14
(3,808 Views)
