How to disable second slider
I have several horizontal sliders that have two sliders. I do this to visualize a limit to the user (in the actual program the limit slider will be transparent). The user should be able to move the first slider (the left one) but not the second slider (the right one).
I don't find an option to disable just one slider in the property nodes. Hiding the slider by making it transparent still allows the user to drag it.
The cleanest solution I found was to set the slider back to the old value in case the second slider was changed. But this causes some visual glitches as the program moves back and forth between the old and new value.
Is there a better way?
(1,041 Views)
What if you would change the scale max to the upper limit such that the right edge is the max for each? Now you actually only need one slider, simplifying the code.
(1,029 Views)
Accepted by topic author Basjong53
If you don't need the 2nd slider at runtime, you can customize the slide ctrl.  Right click on the 2nd slider, check "NoTrackMack".  Then the 2nd slider will be disable for user, but can be changed by property node.  See attached ctrl.
George Zou
(1,009 Views)
What ini key do you need in LabVIEW.ini to get this long menu list?
(986 Views)
enableSecretPopups=True
Take a look this NI Doc:
https://forums.ni.com/t5/Past-NIWeek-Sessions/Customizing-NI-LabVIEW-Controls-and-Indicators/ta-p/34...
George Zou
(982 Views)
@zou  ha scritto:
If you don't need the 2nd slider at runtime, you can customize the slide ctrl.  Right click on the 2nd slider, check "NoTrackMask".  Then the 2nd slider will be disable for user, but can be changed by property node.  See attached ctrl.
Thank you, this is exactly what I want!
(929 Views)
