How to display accurate elapsed time on waveform chart/graph
I have recently been doing small demos on virtual data to get ready for when I use actual data. In this test VI I created a sine waveform that creates a new sample every 100 ms in a while loop. I have scaled the function simply to make it larger. My goal was to be able to display this waveform on both a chart and graph, and I was successful but I can't figure out how to get the x-axes of both the chart and graph to show actual elapsed time in seconds.
I have tried to edit the advanced options in the chart/graph properties and fiddled around with sending clusters into the graph but I can't seem to get it to work. I really don't know what the x-axis is displaying and don't know how to control it.
I have attached my simple VI. Any help would be much appreciated.
Thank you.
Message 1 of 8
(8,694 Views)
Can you save your VI in version 2012 and re-post it.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 2 of 8
(8,679 Views)
The waveform graph's X scale has a default offset of zero, and a default Multiplier of 1.  Since you are sending data to it 10 times per second, you need to set the Multiplier to 0.1.
Then you need to set the display a time format that displays seconds, rather than just hours:minutes like you do now.
Message 4 of 8
(8,671 Views)
Awesome that worked! So the default multipler of 1 means that it assumes 1 sample/second?
Message 5 of 8
(8,662 Views)
Thank you.
Though the delay in the loop is 100ms, it is not very accurate (as your code is running on Windows and not on a Real-time OS) so in order to display the time veryaccurately, you need to use XY graph.
Attached is the example.
Message 6 of 8
(8,659 Views)
That's a very neat solution and gets around the delay issues that I have had.
Thank you!
Message 7 of 8
(8,653 Views)
Actually, it means 1 second per sample.
Message 8 of 8
(8,632 Views)
