Absolute time on x-axis of waveform graph
the solution to my problem must be so easy, that I can't find it.
Please see my small example vi.
I've got a waveform and I want to plot the data against the absolute time. In the graph properties I set the display format to "absolute time", but it didn't work.
transfererror
(5,685 Views)
Accepted by topic author transfererror
I am not sure why this is happening, but your scale ignores the timestamp, but that option is grayed out...
I am not sure why it happened, as it happens for newly created graph elements as well. Modifying the t0 and delta t, i managed to create a graph which does not gray out that option, but with the default settings, there doesn't seem a way to get this to work....
Norbert
Norbert
Expert: Geometry
(5,667 Views)
Thanks for your reply, Norbert
With your help I found the solution.
See attached screenshot.
Nevertheless it seems to be a bug that the option is grayed out in the properties dialog. At least it is missleading.
Best regards
transfererror
(5,652 Views)
transfererror
If Nobert's reply, helped you finding the solution, then you should mark his reply as solution.
You can un-mark your post as solution and mark the appropriate post as solution.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(5,621 Views)
