How to display multi lines in XY graph?
@Freelion8 wrote:
Here how multiple data sets are shown on XY graph (check out the attached vi). You can add more [XY] data sets and connect them to the array so that it will also be shown on the XY graph.
Thanks! But I think my problem is how to take out he data from the 3D array acquired from the hardware directly.
Mei
Message 11 of 18
(1,916 Views)
Didn't we already discuss array operation earlier? Again, you don't need an xy graph. Using a waveform graph is significantly less complicated and can show exactly the same as long as the x-values are spaced regularly, as they are here.
Message 12 of 18
(1,911 Views)
I will change XY graph into waveform graph, but can you please make more detail about the array operation? I am still confused about how to take out the data.
Mei
Message 13 of 18
(1,900 Views)
Accepted by topic author M.Mei
Hi
In my vi, I explained how to draw multiple XY lines on an XY graph. It does not matter in you have 3D or 5D or 2D data. All you need to do is to know how to process your 3D data and feed it into your XY graph. I am attaching another vi which explains how possibly you can process your 3D data and feed it to your XY graph. I hope this will help you to understand the concept.
Senior Software Developer
Message 14 of 18
(1,881 Views)
@Freelion8 wrote:
Hi
Thanks very much!
Mei
Message 15 of 18
(1,865 Views)
did it work for you?
Message 16 of 18
(1,855 Views)
Yes! Your sample inspired me! I can take out data from a 3D array and display multi lines in graph five minutes ago! Thanks again!
Mei
Message 17 of 18
(1,843 Views)
I am happy to help, hit me a Kudo if it deserves one:)
Message 18 of 18
(1,838 Views)
