How to display two readings simultaneously generated on a numerical indicator? Simple thermometer VI and boolean light?
@Dennis_Knutson wrote:
You've got some questionable code. That bottom for loop is just silly. All that you have to do is wire the array directly to the Build Waveform. To create an array indicator, just right click on the array wire and select Create Indicator. To use numeric indicators, you simply use the Index Array function. Please take some of the free LabVIEW tutorials.
The bottom loop indexes each simulated value and outputs a WF for each reading. That part of the code is valid.
Message 11 of 19
(2,008 Views)
Sorry, you are right. I didn't look close enough.
Message 12 of 19
(2,004 Views)
That will teach you to criticize my code.
Message 13 of 19
(1,993 Views)
Now back to the original problem...Use an array of indicators or two indicators.
Message 14 of 19
(1,983 Views)
Brilliant thank you I got the dual indicator via the index array, now just to wire light indicator for average of two values! Should I use a formula node with say y = (X1 + x2)/2?? And wire to lEDS?
Message 15 of 19
(1,977 Views)
No.  Use the Mean.vi that is in the Mathematics->Probability & Statistics palette.  That VI takes in your array and calculates the average for you.
Message 16 of 19
(1,962 Views)
Ok it works perfectly now, took you're advice, thank you to everyone for their help. The only problem I have is that the alarm doesn't sound accordingly, it beeps when temperature is normal or high but not cold? Could this be to do with my comparison elements? Normal is between 16-25 but it wont beep below 16? Can't seem to resolve this?
Message 17 of 19
(1,925 Views)
Look closely at your comparisons and read the help on those.
Just write down exactly what you have wired and you should find your error.
Ben
Message 18 of 19
(1,918 Views)
Should I wire the comparisons to the mean value? and get rid of the 'And Array Elements'?
Message 19 of 19
(1,910 Views)
