How to displayed parced data
Ok, Im having a little trouble with getting data to display in labview. I am reading from a seral string of data that is delimeted with ",". This works fine and I can out put the token stringn. After 7 "chunks"  of data, it will start to repeat itself. How can I get it to display each of these 7 chuncks of data and then on the next loop refersh them.
This is all I have so far
(4,614 Views)
When you say 7 "chunks" do you mean 7 reads?
Also, I would recommend using spreadsheet string to array in this case instead of scan string for tokens.
(4,603 Views)
By chunks I mean the seral data string I am sending LabView has 7 different measruments from a sensor. Each group of 7 is the newest measurment, if that makes more sence. I will take a look at spreadsheet string to array
(4,597 Views)
Accepted by topic author KatherineNSCC
If I understand the problem, you have a string that has a number of embedded commas, and you want an array of strings corresponding to the "stuff" between each comma.  Your reference to 7 "chunks" might imply that each VISA read will return a string of the form x1,x2,x3,x4,x5,x6,x7 (i.e. 7 items, 6 commas), but this solution doesn't care how many "chunks" there are, just that they are comma-separated.
It uses the Match Regular Expression function, with the comma as the Regular Expression.  This VI basically splits the string into two parts, everything before the comma (the upper output, brought out as an array element) and everything else (lower output, put on a Shift Register to be run through again).  Each pass through the While loop pulls off another element, adding it to the array.  When nothing is left, the loop stops.
Consider three odd cases -- string with no comma (get an array of 1 element with the entire string, correct), string starting with a comma (get an array whose first element is an empty string, correct), string of 1 element, ending (or not) with a comma (get an array of 1 element, correct).
Enjoy.
BS
(4,573 Views)
Enjoy.
BS
That does just what I needed!! Thank you
(4,553 Views)
Seems overly complicated. It has already been mentioned that "spreadsheet string to array" is the right tool here (comma delimiter, %s format, 1D string array as type) . No loop needed.
See attached VI. (Image shows that the results are the same for the two versions)
(4,530 Views)
