08-14-2006 01:38 PM
08-15-2006 02:31 PM
Hello Stephanie,
I haven't forgotten about you. I promise.
Your installation order looks fine.
You should not need steps 5 & 6 from your work order. Deploying the library will create the database if needed.
As a check, try doing this...
This should, at least, give us a better understanding of where the issue is.
08-16-2006 09:26 AM
Hi Robert!
Thanks for helping me again.
Yesturday I unintall all National Instruments software on my development computer. I have the Professional Development System... I tried to run my project and I get an error and everything closed. In the past months, I get the same error (http://forums.ni.com/ni/board/message?board.id=170&message.id=194704).... So I guess I have an error in my program but I send it twice to the support engineer and nobody found the problem. I don't know how they test my project but from what I know, the error happens when I have data in the database and when I read the data with "Alarm & Event query.vi". I know that the data is store well in the database (I can see it with MAX) but I can't read them with this VI. If they test my project with nothing in the database, my project works fine. I guess it's not a corrupt file because I reinstall everything more than 3 times now. I finish working on this project THIS friday (in 2 days!!!) and I would like to know why this Alarm & Event query.vi does that error. Is there any other way I can access old data from the database?
Why I have this error http://forums.ni.com/ni/board/message?board.id=170&message.id=194704 in the Development System and why I have this "nids.dll" error with the runtime? And why it's working for you and it's not for me?
I don't want to send my whole project on the forum, is there any way that I could send you my project Robert (if you want to help me, for sure!)?
This morning, I read what you ask me to do and we did something wrong with Windows (ahhh...) so I'm formatting the computer again. After reinstalling everything I'll try what you ask me to do. But if it's not working on the development system, I guess it won't work on the client computer also....
Why, why, why.... ![]()
Stephanie ![]()
08-16-2006 01:28 PM
Hi again,
Today we format the computer. First we intall Windows XP and then the drivers.
I did what you ask me: I intall only DSC runtime 8.0. I perform my application and then the alarms worked good. I simulate alarms with an array of boolean and the alarms were display where they were suppose to be. When I closed my project for the first time, I had this "lvrt.dll" error.... If I run it again, it's the same thing and one of my page cannot be open (the maintenance page, this VI is really simple but with a WMP ActiveX). I had this problem before and (I think) I solve it when I disable the database.
What I don't understand now is that I have the "lvrt.dll" error when I quit my project. Before, I had the "nids.dll" error when I simulated an alarm. I didn't change my code, it's the same thing...
So, what I did is:
1. Format computer
2. Install Windows XP
3. Install drivers + Norton ghost (because we wanted a backup)
4. I install Direct Link 3.8
5. I intall DSC runtime 8.0
6. I run my application on the client computer and I had "lvrt.dll" error when I quit it.
7. I run it again and it was the same thing as #6
8. I download and install DSC runtime 8.0.1
9. I run it again and it was the same thing as #6
So, it's not because of Vision or Remote panel... my development computer has Windows 2000 (who knows, maybe it comes from there).
I did some tests (without the application) on the development computer and it worked (sometimes yes and sometimes no). But when I tried to run the application on this computer, I had an error (the one few months ago).
Now it's lvrt.dll (when I quit), and before it was nids.dll (when there's a new alarm).....
Any ideas why and how to solve this?
Thank you very much
Stephanie
08-17-2006 07:19 AM
Hi!
Hope everybody is doing great!
I just wanted to tell you a strange behavior of my program. Yesturday I did several tests on my development computer (not the executable) and (I don't know why) it worked well. So I decide to build an application with it. I run the application on the client computer and I had the "lvrt.dll" error when I closed it. So I decide to test the application on my development computer and I had an error (the one from few months). Then I tests my VI again on the development computer (not the executable) and it stops working (the error from few months). I even didn't open my VI, I didn't change anything in my code.
Really, I don't understand a thing....
Stephanie who really needs help
08-18-2006 07:08 PM
08-23-2006 09:08 AM
08-24-2006 09:55 AM
08-26-2006 08:57 AM
Hi Matt,
Where can I get the lastest version of LabVIEW DSC RTS (8.20)? We bought version 8.0 few times ago, is it going to cost something to upgrade? Is it available on the internet or we need to buy it again?
What you're telling me is to change version of LabVIEW DSC RTS ONLY?? I don't need to upgrade LabVIEW runtime on the client computer or LabVIEW and LABVIEW DSC module on my development machine? And it's going to work with my whole project?
Thank you very much, I hope it's going to work with this version
Stephanie
08-26-2006 12:24 PM
