How to do a two way comunication using TCP between client/server.
Hi,As I am new to using TCP functions in Labview.Can anyone post or share an example sowing two  way comunication between client/server .Can anyone please upload.I would be very thankful.
(3,416 Views)
Go to find examples and search for TCP, there are really good examples with description how TCP functions works.
(3,397 Views)
If you are doing both sides of the communications with LabVIEW, I recommend using the Network Streams since they autoreconnect and have buffers that you can use.
I would also recommend looking at the STM library (available on the LabVIEW Tools Network).  It is useful for setting up meaningful communication schemes.
(3,376 Views)
