How to do delay in local variable ?
Dear...
Can I do delay in local variable ? ( I dont want local variable to be compatible with terminal, I want some delay (5 to 10 seconds) betweent them. Can I? ) or if you can suggest any procedure to make the same idae......
Please if it possible, modify in this simple attach.
(3,169 Views)
Hi
No, you can not. If a value is written to a terminal, it is also in the local variable.
What do you want to do? Describe more precisely what you want and there are maybe more ideas to come.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,139 Views)
You might be able to simulate this with event programming and a second variable, that is send a value(signaling) to the first value, and inside of the event handle case, put a delay before you send a value to the final variable.  Some more details would help understand what you want to d0.  Other possibilities include state machines and queues with a implicit wait inside of the writer loop.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,116 Views)
I agree with Becktho.  Please describe what you want to achieve (and why), so that we can offer appropriate suggestions.
(3,106 Views)
Here is a solution using Paul's suggestion.  Event and value (signaling).
- tbob
Inventor of the WORM Global
(3,095 Views)
