Missing tools pallette
Hi-
I'm new to labview, and I'm following a tutorial based on the temperature system demo.vi
My problem is that when I click on Windows>>Show tools pallette  Nothing happens; no pallette appears.
What do I have to do to get to the tools pallette?
(2,939 Views)
Maybe it is located offscreen for some reason (e.g. if you used it with a much higher screen resolution).
Try the following:
  1. Exit LabVIEW
  2. Go to your LabVIEW folder (typically C:\Program Files\National Instruments\LabVIEW 7.1 or similar)
  3. Open LabVIEW.ini using notepad.
  4. Delete the entire line containing toolPaletteLoc=.... (e.g. toolPaletteLoc=357,335,516,413 or whatever the numbers are)
  5. save the modified LabVIEW.ini under the same name.
  6. Now restart LabVIEW.
See if this helps. 😄
Message Edited by altenbach on 11-11-2005 12:20 PM
(2,930 Views)
Hi Veneman,
You can also try using the shortcut (shift-right-click) to open the Tools Palette at the location of your mouse.
Hope this helps!
Megan B.
(2,891 Views)
