How to do this nested loop inside labview
i2d=[]
img=[]
for j in range(0,129600,360):
    i2d=[]
    for i in range(j,360+j):
      i2d.append(data[0][i])
    img.append(i2d)
(3,777 Views)
You can easily put a loop inside of a loop.  You could probably do all of the appending of arrays by simply using autoindexing terminals.
(3,772 Views)
there is a 1Darray of length 129600 and I want to create a 2D array of 360x360 out of it
I'm new to Labview and confused to do it
i2d=[]
img=[]
    i2d=[]
      i2d.append(data[i])
    img.append(i2d)
(3,763 Views)
I tried but was not able to do so can you provide screenshots
I'm confused how to append to array that RED BOX
means I am unable to change default array ([0]) with appended array
I'm new to this
(3,766 Views)
Accepted by topic author gptshubham595
Something like this?
Former Certified LabVIEW Developer (CLD)
Currently using LabVIEW 2022
(3,756 Views)
Just wire from one tunnel to the next.  It will go from a 1D array to a 2D array.
(3,742 Views)
