How to download the driver of AT-MIO-16H-9
I have a daq card, it's assembly number is 180705 and board name is AT-MIO-16H-9,my computer is running with windows 98 operation system,I can't find the driver program, thank you for your answer.
(2,598 Views)
Greetings,
The latest version of the NI-DAQ driver that is compatible with the AT-MIO-16H-9 is NI-DAQ 6.1. This driver can be downloaded from the following location:
http://digital.ni.com/softlib.nsf/websearch/14993FD4023B9A86862565A7006F5C80?opendocument&node=132070_US
National Instruments also provides a Hardware Installation Wizard to walk you through the installation and configuration of your hardware and software.
http://ni.com/support/install/
Good luck with your application.
Spencer S.
(2,598 Views)
