How to draw a graph step by step ?
Hi, sirs,
Can you tell me how to draw a graph step by step by using Labview 6.0 ? On one step, I create two variables : one variable is used for X-axis, and other variable is used for Y-axis. Can you give me a simple example ?
Thanks a lot.
(3,825 Views)
unfortunataly I'm not "Sir xxx" , but let's go.
Find attached a sweep.vi - normally used for a GPIB-Instrument - but now sterilized for "test".
There you will find a possible solution, how to show measurement results and how to append Data.
You should play with it; remove the local variables - introduced for show effect only.
regards
wha
(3,825 Views)
Try this VI I created. I am assuming you want an "X-Y" graph since you have two variables (so you are not plotting normal functions, but maybe polar functions instead?)
The VI is easy to use. Choose an X and Y value and then click "plot." Do this multiple times. It's like one of those toys, etch-a-sketch.
(3,825 Views)
Hi, David Duffey,
Thank you for your answer,and I use your example and it is good. But in your program, on the outer loop, there are two small orange color squares in which there is one triangle. I don't know how to add these squares and triangle. Without them, the graph doesn't work. So, can you tell me how to add them ?
Thanks a lot.
(3,825 Views)
The triangle is called a shift register, you right click on the edge of a while loop and select "add shift register."
Once you wire a data type to it, the shift register will change color. The "two orange squares" are simply constants. Or, an array of clusters of two doubles. You can see how I build it up in the loop. I take two doubles, bundle them together, append them into an array, and then wire it to the "up" triangle (right side of loop). I then right click on the "down arrow" and selected "create constant" so that the shift register is cleared every time the VI is run.
I hope this points you in the right direction. There is information in the LabVIEW user manual on shift registers, clusters and arrays that should help you out.
(3,825 Views)
Hi, David Duffey,
Thanks a lot. I get it. It works right now.
(3,825 Views)
