Hi, David Duffey,
Thank you for your answer,and I use your example and it is good. But in your program, on the outer loop, there are two small orange color squares in which there is one triangle. I don't know how to add these squares and triangle. Without them, the graph doesn't work. So, can you tell me how to add them ?
Thanks a lot.
