How to draw a rectangular area on a displayed image using mouse
I am attaching the code I am using for displaying the image which is generated by photo diode as a result of sample scan. Based on this scan I want to select my area of interest (rectangular shape) using mouse which would be a sub-set of displayed image. Please let me know how to do it. I am attaching both the code and excel file.
(The code will ask "Do you want to move motor to desired location" if you will click inside the displayed image.  I have removed the motor-movement part. So, it will just diaplay the coordinate.)
Dushyant
(3,361 Views)
You could do something similar to my example in this recent thread. Let me know if you have questions.
Message Edited by altenbach on 11-01-2005 04:17 PM
(3,359 Views)
The code in second thread worked with minor modification.
Dushyant
(3,330 Views)
I am having some problem in modifying my code as suggested by you. Basically I am also using "Zoom-factor" and "Scroll-bar". If zoom-value is at 100 (i.e. no zoom), I can display the selected area. However if zoom is not 100, I can not select area. Also, the red-dotted area which appears in original picture in your code, appaears in "selected" (i.e. resultant image) in my code. I could not sort out these issues.
I am attaching my code n an excel file.
Dushyant
(3,319 Views)
Well, you just need to keep track of the zoom factor in some way.
Basically, you just made a mess out of my code by adding unneeded shift registers and other odd constructs. I spend a few minutes to clean it up a bit. Seems to work OK now. 😉
(3,312 Views)
It worked.
Dushyant
(3,308 Views)
