How to dynamically rename a DAQmx physical channel array?
Hello!
I am a bit confused on how to work with array of DAQmx channels.
I just want to replace the "Dev5" of my DO channels with whatever name come from the for loop.
How can I do that?
The reason is that the user can connect different testbox to the PC, so it would always be a USB-6341 or USB-6210 but with a different name in NI max (Such as Dev2 Dev3 Dev4 etc...). So I want to detect what is connected and change the DAQmx channels names accordingly.
Ludovic
(1,365 Views)
Hi Lchar,
the channel array can also be an array of strings.
And you can format/edit strings as required...
(1,353 Views)
Accepted by topic author Lchar
Had a couple free minutes here to illustrate one way to accomplish what GerdW was referring to...
-Kevin P
(1,325 Views)
Your solution looks cleaner than what I have just done:
Thank you both for your time!
(1,317 Views)
