How to efficiently animate a side-view valve; 0' to 90' in 1' increments
I'm looking for advice on how to draw a cut-away view of a section of pipe, showing a throttle-plate style valve inside of it.  I want to animate the valve from 0' (closed) to 90' (wide-open) in 1' increments.  I'd like to do this without drawing 90 unique images for a picture control.
I'll have three of these on my front panel, so it has to be efficient.
Thanks in advance
Jeff Grimes
Ford Motor Company.
(3,012 Views)
I've attached a picture control animation. Its probably not what you want (valve shape), but I hope it puts you in the right direction.
This functionality could be put into a subVI and have the angle as input parameter and a picture a s output to connector to a picture indicator on the front panel.
André
BTW its in LV 8.2
Message Edited by andre.buurman@carya on 08-03-2007 03:04 AM
André (CLA, CLED)
(3,003 Views)
Thanks, Andre, I'll take a look.
(2,988 Views)
You might also wish to check out Altenbach's example here.
___________________
Try to take over the world!
(2,979 Views)
