How to eliminate advapi32.dll error in Labview RT
Hi all,
I am having a problem deploying a RT application to the remote machine. I get an error stating Error loading 'WS2Help '.dll: Missing
export 'AllocateAndInitializeSid' from ADVAPI32.DLL'  After searching the internet for a while I know that this is a dll that the labview realtime os cannot use.  However I do not know if there is a tool/debugger that I can use that will tell me what vi's are calling this dll.  If I know what is calling it I figure I can figure out an alternative to that function.  Any help is appreciated. Thanks.
(3,563 Views)
will this help you?
Mathan
(3,522 Views)
I was reading that thread before, but thank you because I see there is a new response.  Perhaps my idea that the dll is not supported is incorrect.  The odd thing is when I deploy it, I will get the error but the program will run.  However if I build an executable to deploy it (I want the program to start when I power on the box, as far as I know I need to build the .rexe for this) I do not get a successful deploy. I wish I would get an error code in one of these steps at least.
(3,515 Views)
Hi KidMoe,
In addition to the information (and the program) from the thread that mathan linked, here is a little more about that dll.  WS2Help.dll is used by Internet and network applications.  Specifically, the file contains functions used by the Windows Sockets API.
(3,487 Views)
That is a Photoshop file, is that installed on your PC? If so, reinstall Photoshop to see if that rectifies the problem.
(3,014 Views)
