01-20-2009 09:31 AM
Hi all,
I am having a problem deploying a RT application to the remote machine. I get an error stating Error loading 'WS2Help '.dll: Missing
export 'AllocateAndInitializeSid' from ADVAPI32.DLL' After searching the internet for a while I know that this is a dll that the labview realtime os cannot use. However I do not know if there is a tool/debugger that I can use that will tell me what vi's are calling this dll. If I know what is calling it I figure I can figure out an alternative to that function. Any help is appreciated. Thanks.
01-20-2009 10:04 PM
01-21-2009 07:00 AM
I was reading that thread before, but thank you because I see there is a new response. Perhaps my idea that the dll is not supported is incorrect. The odd thing is when I deploy it, I will get the error but the program will run. However if I build an executable to deploy it (I want the program to start when I power on the box, as far as I know I need to build the .rexe for this) I do not get a successful deploy. I wish I would get an error code in one of these steps at least.
01-22-2009 09:30 AM
Hi KidMoe,
In addition to the information (and the program) from the thread that mathan linked, here is a little more about that dll. WS2Help.dll is used by Internet and network applications. Specifically, the file contains functions used by the Windows Sockets API.
10-30-2011 10:14 AM
That is a Photoshop file, is that installed on your PC? If so, reinstall Photoshop to see if that rectifies the problem.
