How to eliminate the delay in Xcontrol?
As the attachment shows, I need to add a delay in the Xcontrol Facade  block diagram, but during its running, the test panel for the Xcontrol won't respond for any other command( for example: click an button). So this feature makes my program very unconvenient.Smiley Sad
LabVIEW 8.20程序设计从入门到精通已经出版,敬请关注!
欢迎访问LabVIEW学习乐园: http://labviewstudy.blog.edu.cn
Message 1 of 16
(4,936 Views)
the attachment
Message 2 of 16
(4,919 Views)
 up
Message 3 of 16
(4,907 Views)
more new problemswhen you create several Xcontrol in a cluster and then use cluster's property of controls as reference to access the property and method of the Xcontrol, it works properly, but when wrap it to exe, the xcontrol would fail to work.:
Message 4 of 16
(4,892 Views)
up stairs:P
Message 5 of 16
(4,875 Views)
Your attached zip files seem to be corrupt. They cannot be opened. 😞
Message 6 of 16
(4,873 Views)
I cannot open your attachment, but I have a really hard time trying to imagine any reason why anyone would want to add a delay to an Xcontrol. It just feels wrong!
Could you explain your reasoning?
Message 7 of 16
(4,874 Views)
Sorry, I zip this file with WinRAR, and I changed the extension to ".zip", so you may need to change the extension back to ".rar" after you downloaded it.
I need to add a delay in the Xcontrol cause I want to see blinking with an indicator when alarm happens.
thank you:)
Message 8 of 16
(4,870 Views)
Ahh, this seems like important information. 🙂
I very briefly looked at your xcontrol, but I have absolutely no idea why you need a delay after setting the blinking property. Since you don't unset the property, the delay has no meaning or purpose..
I am also pretty sure that your xcontrol desgn is incorrect. I don't think there should be much in the timeout case, but you seem to pile all your code there. You also never modify the action and state clusters or even the data out. Then you have all these shared variables...
I would recommend that you study the shipping example"simple dual mode thermometer" (search for xcontrol in the example finder) for some guidelines.
What exaclty is the purpose of your xcontrol? What is is supposed to do?
Message 9 of 16
(4,854 Views)
Did you run my example? If there is no delay, you cann't see the blinking of the control.
Message 10 of 16
(4,838 Views)
