how to filter a signal with labview 7 basic package
Hello, I have a signal which are too noisy. I would like to use a filter to reduce the noise. However, I have the .0 basic version of labview. I attached the Vi to this message. Do you know how I can filter the signals?
Anny
Message 1 of 11
(4,455 Views)
Hi Anny,
As you must be already aware, LabVIEW base package does not come with filters.
Herez what i Suggest, try to implement some simple algorithm for a low pass filter like moving average/Smoothing filters( adjust the size of moving average window to get good noise cancellation) using labview mathematical functions and you must be able to get fairly better data. with lesser fluctuations.
Look at these links to get an idea on how to implement it.
http://www.dataq.com/applicat/articles/an14.htm
Regards
Dev
Message 2 of 11
(4,443 Views)
I installed the Labview 7.0 Full version. I used the filter to reduce the noise in my 4 signals. The Vi is in attachment. I would like to know if this correct and also if all 4 signals are filtered.
Message 3 of 11
(4,425 Views)
I forgot to attach the Vi. Thank you very much.
Message 4 of 11
(4,424 Views)
aurelia,
Yes, the express VIs are that easy to use!  You should try to change the filter settings on the configuration page (accessed by right-clicking and selecting Properties on the Filter Express VI) and watch the results to see if the signal is getting filtered to your liking or not.
Hope this helps!
Andy F.
Message 5 of 11
(4,404 Views)
hi Anny,
As Andy has already told, express Vi's are indeed the quickest way to realise filters.
Since you now have a Full Development System, do go ahead and use all the filter functionalities that come with it.
There are a lot of examples which will help you to get started
Best regards
Dev
Message 6 of 11
(4,399 Views)
I ran the attached Vi with and without the filter. IWhen there is a filter, I got a voltage that is 4 times lower than when there is no filter. Do you know why? Is this because I have 4 signals? Thanks
Message 7 of 11
(4,384 Views)
aurelia,
I might recommend taking a look at the filter examples that Dev referenced (Help >> Find Examples).  This should give you some more info about how filters work.  I would recommend changing the filter cut off frequency and observing the changes in the preview window when configuring the properties of the Fileter Express VI and see if it is giving you the filter response that you want.
Andy F.
Message 8 of 11
(4,363 Views)
hi dev,
You said that i can apply moving average algorithm in order to filter the signal...can you give me the example on how to write a code in labview 8 base package with the moving average algorithm?
Message 9 of 11
(4,255 Views)
This VI will demonstrate Moving average alorithm.
This i had downloaded from forums in the past. Smiley Wink ( must be Bektho's creation)
Hope this helps
Regards
Dev
Message 10 of 11
(4,245 Views)
