How to enter a value in an input box with set xy-coordinates in another stand-alone program
I need to enter a value in a stand-alone windows program (just an industrial executable that I have no control over). Essentially I just want to automate manual key entering to avoid having to do it manually by:
1. Place the cursor over the screen xy-coordinates where the text input box is located
2. Click
3. Enter value
4. Press enter
Cheers,
Mattias
(3,433 Views)
Hello Mattias,
NI has an article on how automate keystrokes here: https://forums.ni.com/t5/Example-Code/Programmatically-Simulate-Key-Strokes-in-LabVIEW/ta-p/3521756
Good luck with your project!
Looking a little closer, I don't think my link above will do quite what you're looking for.
Have a look at this older post here:  https://forums.ni.com/t5/Example-Code/Programmatically-Simulate-Key-Strokes-in-LabVIEW/ta-p/3521756
There is also another method of simulating keyboard events:  https://forums.ni.com/t5/Example-Code/Using-LabVIEW-to-Simulate-Keyboard-Events/ta-p/3996210
Patrick Allen: FunctionalityUnlimited.ca
(3,421 Views)
Great, thanks Patrick,
I've had a look at the code, but unless I make a mistake, there is no way to select where on the screen I want to enter the code?
The stand-alone industrial processing control program I'm trying to control covers the whole Windows screen and has more than 30 fields/boxes where one can enter values, but I only need to change the values in one of the boxes during processing (which can run for hours, which is why I don't want to sit there and manually enter numbers all day).
Is that possible with the program you supplied and I missed it?
Cheers,
Mattias
(3,404 Views)
Accepted by Mattias_247
Oops, it seems I accidentally posted the same link twice.
This was the second link I meant to post.
https://forums.ni.com/t5/LabVIEW/Can-LabVIEW-control-another-program-or-emulate-keys-pressed-on/m-p/...
The above post mentions something called AutoIT.  I have not used this personally, but there are a few examples of using it with LabVIEW.
To simulate a mouse click to select the active region in your other program, have a look at this post here: https://forums.ni.com/t5/LabVIEW/Can-LabView-generate-a-mouse-click-for-another-program/td-p/795252
There is some example code here: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000015ASTSA2&l=en-CA
It might take a some time to get all the coordinates of the places you need to click.  But at least you would only have to do it once.
(3,383 Views)
Ha ha, great, thanks, I think that'll do the trick, many thanks.
(If I don't get it to work, I may ask more questions!)
Cheers,
Mattias
(3,377 Views)
