How to exactly calculate the resolution of a load measurement using the 9237?
       I'm using the NI 9237 to acquire a load measurement. I would like to calculate the resolution but I'm not sure about the way to do it.
Based on the information on the website http://www.loadcelltheory.com/loadCellResolution.html.
The calculation is attached to this message. Sorry in advance if the text is in french. I guess that it will be easy to understand by reading the english website.
Thank you
Am I right?
(3,190 Views)
Your link was defective because there was a period at the end.
It should be http://www.loadcelltheory.com/loadCellResolution.html
The NI 9237 has 24 bit resolution.  So take whatever range it has and divide it by 2^24 and use that in the calculations you linked to.
(3,183 Views)
