How to execute a series command automatically
Thanks. But it seems that this will not work for multiple I/O?
Message 11 of 24
(2,971 Views)
Your timing may be off because the code is not enforcing the wait to occur after the VISA command. The wait function was floating in space, which means that there is no guarantee that it will occur before, during, or after the call to VISA write. Use the error cluster to enforce data flow:
Feel free. Contact me for anything more,
    Pang
You too can be LabVIEW Awesome!
Message 12 of 24
(2,964 Views)
I think we'd better look at the manual.  I don't think commands are being sent exactly correctly.  Needing hardcoded waits almost always signals that there is an incomplete understanding of the sending and receiving of data.  Unless the manually specifically states that you need to insert hardcoded waits, there's usually no need for them.
Bill
CLD
(Mid-Level minion.)
Message 13 of 24
(2,947 Views)
Here is an actual example of the way I write a series of commands to an instrument.
=== Engineer Ambiguously ===
Message 14 of 24
(2,907 Views)
I do the same as RTSLVU.  As far was the wait inside of the loop, some instruments do not need the wait, others need 50ms, others 500ms.  So do not be surprised is something does not work because you did not allow the instrument to do its thing before the next message comes in.
Message 15 of 24
(2,893 Views)
Yeah, I had to add that 200mS because on the older Ci5000 units we have can't take it in any faster. I would get a "comand buffer overflow" error or something like that.
Message 16 of 24
(2,884 Views)
At least you got an error.  I had an oscilloscope that would appear to not even process the command unless I had a 500ms wait between commands.  Granted, I think it did actually do the command, but other things it was processing due to previous commands over-wrote the settings I gave it.
Message 17 of 24
(2,875 Views)
Thank you for everyone's help. I have evetually used QMC and state machine to address my question.
I did have to add 30000ms wait time for some command, it is just how my instrument work ...
Best to everyone!
Message 18 of 24
(2,852 Views)
Half minute wait time? Smiley Surprised
Message 19 of 24
(2,838 Views)
It would be a good time to upload the manual.
Bill
CLD
(Mid-Level minion.)
Message 20 of 24
(2,825 Views)
