How to execute a series command automatically
Yes. syringe can move very slow, and the instrument refuse to accept new command before it finish moving
Message 21 of 24
(1,511 Views)
There must be a command to read the status of the syringe?  But I'm not going to guess any more.  Speculation is fruitless at this point.
Bill
CLD
(Mid-Level minion.)
Message 22 of 24
(1,509 Views)
I just checked the manual
Yes. You are correct. there is a command to check the pump status.
I now need to think about how to add that command to my state machine vi so that I only send the next command when status is 1. probably use wait until ...
the attached is the manual. it is mentioned on page 3-32 or page 68
Message 23 of 24
(1,494 Views)
Accepted by flylark1977
So you add a "check statuts" state.
Ater sending a "start pump" or "stop pump" command go to "check status" and check the status at regular intervals until the status is 1
=== Engineer Ambiguously ===
Message 24 of 24
(1,486 Views)
