How to execute un .bat file with labview
Hi everyone,
It's all clear in the subject, so how to execute un .bat file via LabVIEW?
(2,772 Views)
Use the System Exec block.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,764 Views)
Use the System Execute command under Connectivity >> Libraries and Executables palette.
(2,760 Views)
I've used it but it didn't work
maybe i've used it in a wrong way.
so what i did, i've make the path of the file an input for the command line parameter. it is correct?
else how can i make it work
thnks in advance
(2,755 Views)
We don't want to do your work for you (you aren't paying us).  However, if you do the work, and attach it to your Reply, we are happy to look at it and suggest how you "fix" it.  You'll learn more by doing it, yourself ...
(2,742 Views)
well said @
(2,739 Views)
