09-06-2019 09:09 AM
Hi everyone,
It's all clear in the subject, so how to execute un .bat file via LabVIEW?
09-06-2019 09:12 AM
Use the System Exec block.
/Y
09-06-2019 09:13 AM
Use the System Execute command under Connectivity >> Libraries and Executables palette.
09-06-2019 09:18 AM
I've used it but it didn't work
maybe i've used it in a wrong way.
so what i did, i've make the path of the file an input for the command line parameter. it is correct?
else how can i make it work
thnks in advance
09-06-2019 09:40 AM
We don't want to do your work for you (you aren't paying us). However, if you do the work, and attach it to your Reply, we are happy to look at it and suggest how you "fix" it. You'll learn more by doing it, yourself ...
Bob Schor
09-06-2019 09:45 AM
well said @Bob_Schor , that's the spirit of the community
