How to export XY graph picture to clipboard (or file) with labview 6i
I would like to export XY graph picture to clipboard (or file) to insert it in a word document using labview 6i
I found example for labview 8 using invokenode but not with labview 6i
But this invokenode doesn't exist in labview 6i : here's what I found in labview 6i
 Does anyone knows how to use this one ?
thanks in advance
(5,006 Views)
Accepted by drxl
Wow, hadn't launched LV6i in a while, never realized how much I rely on the auto tool selection.
You can wire that invoke node directly into the "Write to JPEG File.vi"
(4,994 Views)
it works fine
Thank you.
(4,979 Views)
I would recommend you use Write PNG File.vi instead of Write JPG File.vi unless the place you are using it cannot handle PNGs.  The PNG will be much better quality and should be about the same size for this type of image.
Message Edited by DFGray on 02-03-2010 07:22 AM
(4,961 Views)
Thanks for your comment
I will do the change
(4,957 Views)
