How to extract the gray value of gray image and represent it with two-dimensional array?
Hello!
I am new to Labview and would like some help. I want to extract the pixel value of a gray image for subsequent defect detection. How should I write the program?
Like this picture:3.jpg
Please tell me more details,thank you very much!
(2,369 Views)
Step 1) Make a vi that opens the image file.
Step 2) Report back to this thread with progress on the open image file vi.
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
(2,319 Views)
Accepted by topic author Alert77
Assume you do not want to use NI Vision, just want to develop based on LabVIEW basic functions, then
1) use "read JPEG File.vi" read your image;
2) unbundle the image data from the step1 result, if you want to have flatten data;
3) use "Unflatten Pixmap.vi" if you want to unflatten data.
(2,303 Views)
Thank you very much for your reply, but I just started to study, so I don't understand your reply very well. But I received a more detailed answer. Thank you in the end!
(2,275 Views)
Thank you very much for your answer, but I would also like to take the liberty to ask, what should I do if I need to use Ni vision?
(2,272 Views)
if you have NI Vision, then you can use "IMAQ GetPixelValue" to obtain the pixel value in you image directly.
(2,243 Views)
Thank you very much! I got the data.
(2,238 Views)
