How to fast split a string in sub-strings
i have a string with 8 fields divided with a separator. For example:
C|text|20140910-132435|1|A|0,000|0,000|3
Currently i use "MatchPattern" to split this string into the fields.
For 200.000 loops it akes ~1sec
Can this be done faster?
Message 1 of 12
(5,450 Views)
Maybe simpler would be to use spreadsheet string to array with '|' as delimiter. Array type 1D-array of strings.
I wouldn't expect this method to be faster, though.
Message 2 of 12
(5,440 Views)
Thanks. I tested it but ist 0.4sec slower against MatchPattern.
Message 3 of 12
(5,425 Views)
I've modified your timing setp up slightly.
There's no need to subtract and update the indicator 20k times.
Message 4 of 12
(5,409 Views)
If your format is never going to change, I like the Scan From String.
Message 5 of 12
(5,399 Views)
@Richard_Ha
I can only open Vi´s Labview 2013 😞
How to set the format-string for ScanFromString? %s|%s|%s|%u|%s|%f|%f|%u is not working, how do i set the separator here?
Message 6 of 12
(5,376 Views)
Use "[^|]" for the strings.  That will give you a string up to (but not including) the |.
Message 7 of 12
(5,353 Views)
2013 Version
Message 8 of 12
(5,342 Views)
Simply moving the string to number conversions outside the loop reduced time by a factor of 3 on my system (280ms for your code to 90ms).  I had to replace the scan from string to fract/exp string to number, but the string functions will take arrays and output arrays.
EDIT:  I also moved the timing calculation to a frame after the for loop to remove the needless update of the indicator for my numbers above.
Message 9 of 12
(5,326 Views)
Are you also making use of parrallel for loops?
Message 10 of 12
(5,320 Views)
