I get this Error: MsiError 87 Unhandled MSI Error. when i run an application installer on my 64bit machine.
I have LabVIEW 2013 SP1 (32-bit) installed on 64bit machine everything was fine untill i tried to create an installer for my LV application the install build finishes with no error but when i try to test the installer i get the following error:
My installer includes the NI LabVIEW Run-Time Engine 2013 SP1, and my application excutalbe runs fine with no errors. at this point i have no idea what is causing this error and i couldn't find any asnwer in the forum that can help so any hint will be appreciated.
Samir F
Electrical/Software Engineer
Transtechnik-USA Corp
(3,712 Views)
are you running as administrator?
(3,660 Views)
Yes i have Surun software installed that allows me to run applications as an administrator.
(3,651 Views)
Hi  thanks for the reply
I already went thru that post before and i already tried the following:
1. I created a new fresh project and added the files to to it and built the executable and installed from it.
2. I reinstalled the windows installed as it was suggested here
3. I also tried editing the project file using Notepad by removing the build informaiton and started fresh with new build.
none of the obove solved my problem.
(3,634 Views)
Sam I have this issue as well.  Were you able to get it resolved?
(3,471 Views)
It looks like a labview bug. i upgraded to LV 2014 now i dont get this error.
(3,460 Views)
