How to find a modem's com port number programmably if I know the name of the modem interface?
Hello there,
I know if I see a modem device under Device Manager, I can right click on it, go to properties, then click on Modem tab to get the com port number for this modem device. But how do I do it programmably in Labview? I'm hoping I can search by the modem name which is known to me then retrieve the com port number in labview code. I tried the Visa Find Resource.vi but didn't get anything useful. Has anyone have any experience on this?
Spring
Message 1 of 15
(5,961 Views)
You are on the right track. I would start with Find Resource to find available Com ports then check any Com ports for presence of the MODEM.
I am not sure what the MODEM command would be but in IEEE 488.2 I would send a *IDN? (Identify) query, then check the response to see if it is the device I am looking for.
=== Engineer Ambiguously ===
Message 2 of 15
(5,913 Views)
Hayes command set. https://en.wikipedia.org/wiki/Hayes_command_set
Message 3 of 15
(5,892 Views)
Have you tried perusing these properties to see if they yield anything useful?
Message 4 of 15
(5,867 Views)
Thanks RTSLVU and Paul for trying to help. Paul, yes, I've tried all of these properties and some other ones too. They either return useless information or they don't return anything because Labview generates errors. Please see the attached pictures. What's confusing me is that I can clearly see the modem name under device manager: "u-blox ...". Why does none of these properties give me that piece of information?
Message 5 of 15
(5,851 Views)
Here's some of my old device finding stuff/
Message 6 of 15
(5,832 Views)
Yeah, I don't think the property node is going to work. I believe that is only for IEEE 488.2 compatible devices.
Have you tried the Hayes commands on detected ports?
A quick skim through the Wiki it looks like ATI0 might give you the information you are looking for.
Message 7 of 15
(5,822 Views)
I think Windows gets all that information from the .INF file when you installed it.
I don't know how to make LabVIEW get the same information.
Message 8 of 15
(5,815 Views)
Hi Paul, I can't open your files because yours is newer than my labview version which is 2014. Thanks.
Message 9 of 15
(5,776 Views)
Hi RTSLVU,
Actually I do have a list of AT commands which work on this device including ATI0. Originally I wanted to locate the device first then send AT commands to test it. Now it looks that this path is leading to nowhere, so I guess I'll have to change the approach. I'll send AT commands to each of the found port and look for the reponse string to locate the modem. Thank you again for looking into this issue.
Spring
Message 10 of 15
(5,764 Views)
