How to find a modem's com port number programmably if I know the name of the modem interface?
Accepted by topic author 2014spring
Here it is in LV 2014
Message 11 of 15
(1,750 Views)
Hi Paul,
Wow, your "old" stuff really shined a light on me. You got a lot of stuff there and I think I'm overwhelmed by the power of your code! I alreay saw my modem showing up there with the name and com port number all together...ha...I'll try to digest a little better and pull out the part that I really needed. Did you write all those get managementbase subvis, Paul? Anyway, thanks a bunch for sharing your old stuff! It's very helpful!
Best,
Spring
Message 12 of 15
(1,723 Views)
@2014spring wrote:
Hi Paul,
Best,
Spring
I did write the management VIs, but I figured it out by looking at other peoples' code (don't remember who or when).
Message 13 of 15
(1,064 Views)
Hi Paul, I'm facing a new problem now. I have two devices that all show as "USB Serial Port" in Device Manager. The only difference that I found is their hardware ids in the properties. I tried "Get_USB_List_and_Props PLUS.vi" with filter "Select From Win32-USBDevice". It returns devices with Hardware ids but no COM port numbers. How do I get both Hardware id and COM port number in LabVIEW?
Message 14 of 15
(1,062 Views)
Sorry, I don't know.  I've had a similar problem and tried many times (always failing) to find the relationship between a COM port number and an identifier (such as a USB path) to a particular piece of hardware.
Message 15 of 15
(971 Views)
