09-25-2007 09:11 AM
tst,
The point I m repeatedly trying to emphasise is, as you know well, LV should NOT AT ALL ask for a dll that is already owned by it, during the build-time or ever thereafter.
All these years this project has been existing in our company [now the 4th yr running], LV has not ever asked for that dll [for that matter, any other dll owned by it] during build-time or after that or even in a non-LV PC.
The dlls that re going to be put into the data folder are those that re supplied by us, meaning used by our application [EXE].
I reiterate this because I use the Browse Folder.vi posted by you in a old thread to give the user a Windows Folder Dialog for the look of it. It uses the shell32.dll for calling two functions. But, LV wont put this dll into the data folder because this is a windows dll & there is no point for LV to doubt that whether this dll will be available in a particular PC.
Similarly, LV wont put its dll into the data folder because it cannot doubt its existence in the PC where the application is to be run. But, to avoid the worst-case scenario, anyhow LV binds it with the run-time engine to make sure it gets installed in the PC where the EXE is installed.
Am I right ?! Or, correct me please...
09-25-2007 09:14 AM - edited 09-25-2007 09:14 AM
Message Edited by lmtis on 09-25-2007 09:17 AM
09-25-2007 09:33 AM - edited 09-25-2007 09:33 AM
Message Edited by pincpanter on 09-25-2007 04:33 PM
09-25-2007 09:33 AM
The RTE folders are in National Instruments\Shared\LabVIEW Run-Time.
As you said, it looks like in 7.1 lvanlys.dll should already be in the RTE folder and the application should take it from there.
If it's not like that on your computer, that would seem to be the likely reason why you're getting this error.
09-25-2007 10:26 AM
tst, I checked all the locations, but the problem has not get solved yet.
One more thing I m unable to understand is ho come LV RTE 7.1.1 is installed in my PC & also the corresponding folder doesnt exist in its location.
Please see the attached pics.
I m also following everybody's advice, but still nothing seems to work out in my favour.
Will the devie drivers of LV released Nov 2006 install 7.1.1 RTE ? Anybody please explain to me.
I m totally clueless.
09-25-2007 10:36 AM
@pincpanter wrote:
Partha, with 7.1 (unlike 7.0) you need to check Analysis vis support in the Advanced Installer Settings in order to include lvanlys.dll into the installer. This dll does not appear in the support and installer file lists, so it's not copied to the support file (data) directory.
Paolo,
It is getting built without any fuss in my team-mate's PC just 5 min before, after I posted my previous reply.
Now the in-house production testing is going on & ll go all thro' the night.
09-25-2007 10:39 AM
09-25-2007 10:42 AM
09-25-2007 10:43 AM
Paolo,
It is 7.1.1, see the pic.
How did it get installed without my knowledge & permission ? I m annoyed.
I ve not installed anything unknown to my capabilities.
09-25-2007 10:52 AM
Dennis,
My MAX shows LV 7.1 RTE only. Please see the pic.
But my Control Panel Add/Remoce Programs shows LV RTE 7.1.1. Please see my earlier post.
Could this have happened due to the installation of the Device Drivers of Nov 2006 ?
If I uninstall RTE & reinstall using the old CDs of 2005 or before, will it become OK ?
