How to find average time taken by the data?
Hi prabesh,
@prabesh99 wrote:
Could you please help me to solve this problem?
Yes, I can help: implement my latest suggestion!
Message 31 of 42
(1,256 Views)
Dear Gerdw,
Thank you for your response.
yes, I did your latest suggestion but it did not work.
Message 32 of 42
(1,250 Views)
the latest version is found here, but not in your VI...
Message 33 of 42
(1,246 Views)
Dear GerdW,
Sorry to bother you again. I did what you told me to do, but it did not work again. I got the repetitive data and if I vary the sample length I got the same data. I have attached the Lv2017 as well as a pic.
thank you
Message 34 of 42
(1,223 Views)
Dear Gerdw,
I found a snippet on the community, and it works well. However, Whenever I run for the second time this VI, I got previous as well as new data. How can I remove previous data?
I have attached the LV2017.
Thanks in advance
Message 35 of 42
(1,216 Views)
Hi prabesh,
Ofcourse you will get repetitive data: you wanted a new average value after each "sample length" samples! So when you set that to 100 then you get 100 times the same value, then a new value for the next 100 samples!
When I change the "sample length" to 10, then I get a new value each 10 iterations:
Message 36 of 42
(1,209 Views)
Hi prabesh,
Clear any shift registers.
Clear the chart history…
Message 37 of 42
(1,204 Views)
Hi Gerdw,
thank you for your message. I cleared the chart and shift register too but still, the previous data has been replaced yet by a new one.
Thank you
Message 38 of 42
(1,200 Views)
Hi prabesh,
@prabesh99 wrote:
NOW: I cleared the chart and shift register too but still, the previous data has been replaced yet by a new one.
BEFORE: Whenever I run for the second time this VI, I got previous as well as new data. How can I remove previous data?
First you wanted to delete previous data on next run of the VI - now you wonder why previous data has been replaced "yet by new one"?
What exactly do you need?
Message 39 of 42
(1,196 Views)
Hi Gerdw,
Thank you for your prompt reply. For the second time running VI, I got both data previous data as well as new data. I want new data only. Whenever I run Vi for the third time or any time, I got the data from 1st running, 2nd running, and as many times as I run the VI. I want the data from the latest Vi that is run last time.
Thank you
Message 40 of 42
(1,193 Views)
