How to find factors of the 4th degree polynomial
Hello!
I have 4th degree polynomial like this:
y=x^4+18*x^3+52420*x^2+34303*x+51959400
Is it possible to present this in LV in the form like y=(a*x^2+b*x+c)(d*x^2+e*x+f) ?
I tried to use the PFE function, but I don't get the correct solution with it. I know that there is a method described by Lodovico Ferrari, but I don't know how to use it in LV
(3,030 Views)
Hi spalinowy,
You need to solve this puzzle:
a*d = 1 (I would assume a=d=1)
a*e + b*d = 18 (= b+e, with first assumption)
a*f + b*e + c*d = 52420 (=f + b*e + c, with first assumption)
b*f + c*e = 34303
c*f = 51959400
(3,020 Views)
b*f + c*e = 34303
c*f = 51959400
Is it based on some theory?
Where can I find something about it?
(3,008 Views)
Hi spalinowy,
y
= (a*x² + b*x + c)*(d*x² + e*x + f)
= a*d*x²*x² + (a*e + b*d)*x³ + (a*f + b*e + c*d)*x² + (b*f + c*e)*x + c*f
= x²*x² + 18*x³ + 52420*x² + 34303*x + 51959400
Basic math…
(3,005 Views)
Sometimes I have the simplest things become unclear when I slept 3 hours 😴
(2,995 Views)
Why do you want to factor it?  LabVIEW can easily evaluate a quartic just as well as a pair of quadratics.  If you know the coefficients of the two quadratics are all integers, it shouldn't be a dfficult problem to write a LabVIEW routine to find them (best left as "an exercise for the Reader", who will probably learn something in the process).
Bob Schor
(2,934 Views)
This polynomial is the denominator of transfer function. On the Bode chart there are 2 resonances, and if you divide it into two polynomials, of 2 degree will have two characteristics with single resonances.
(2,920 Views)
