Radio buttons all connected to property nodes
I want to connect each radio button to a property node so they all get updated at once.
Message 1 of 25
(3,821 Views)
Hi RHutchings,
What exactly do you want to connect?
What is "each radio button" when your "Script View" control is just one radio button control (with several items inside)?
What do you want to achieve?
Message 2 of 25
(3,812 Views)
Message 3 of 25
(3,808 Views)
I want to view these text boxes as I select them. I want all the others to be hidden.
Message 4 of 25
(3,806 Views)
Hi RHutchings,
There are no "text boxes" in your VI or your image.
What do you want to hide?
(Why don't you use an ordinary enum control instead of readiobutton control when you want only one item visible to the user?)
Message 5 of 25
(3,800 Views)
Will the enum box reset all other text box views to false? I only show the property nodes to the text boxes set to view.
Message 6 of 25
(3,792 Views)
Hi RHutchings,
Which "textboxes" are you talking about? You didn't show them nor do you explain them…
  • An enum control only shows a single item: check.png
  • When your "textboxes" are those other items in the Radiobutton control: in a radiobutton only one item can be TRUE, all other are set to FALSE automatically…
You still didn't explain in a clear way what you really want to achieve!
Message 7 of 25
(3,787 Views)
The only way I see to do this is to have a case select with all the nodes in each case. That doesn't seem like the right way to go about this.
Message 8 of 25
(3,786 Views)
Hi RHutchings,
Please explain what you are trying to achieve!
What are "do this" and "about this"?
Message 9 of 25
(3,782 Views)
As clear as I can say it, I have 6 textboxes that I would like to have hidden until I need to edit one.
Message 10 of 25
(3,780 Views)
