07-27-2017 09:39 AM
is it possible to find out the sampling frequenz. I've got a incoming signal that I low- and highpassed (0,5-4Hz) with a 88Hz sampling frequenz.
Now I want to get the time between 2 points/peaks/valleys. To do this succesfully, I need to know the sample rate. How can I find this out?
07-27-2017 09:50 AM
07-27-2017 10:18 AM
Hello Gerd,
I have got the ADC LTC2440.
The SDI Pin is on ground, so the output Rate is 880Hz. But I do not think that's my sample rate 😕
I filtered with fs=88Hz, so I sample the output data with 88Hz ?
07-27-2017 11:37 AM
